I have added the configuration options of Creo 4.0 on www.ProESite.com and updated the 3.0 and 2.0 options:
You can check them out here: ProESite - Olaf Corten's Creo Site - Pro/E Utilities, Benchmark, Tips and Links
Disclaimer:
These options include all the hidden (undocumented) options as well. The hidden options are usually provided for internal use by the QA department of PTC during the development of new releases and are normally not intended to be used by customers in production. Be carefull using these options. They are unsupported, and might make your system unstable or your models corrupt.
Thanks, Olaf Corten!
I've created and updated the Notepad++ User Defined Language files for Creo Parametric and Pro/ENGINEER according to your changes.
