Creo 4.0 Not Utilizing all RAM during Lattice Generation
Modulerics
3-Newcomer
Hey,
Specs Below. I'm working on Generating a Lattice (simplified ref) and my computer is struggling. I only seem to be using 6% of my CPU, only 5 GB of RAM and none of my GPU.
Is there anyway to get Creo to access more of what's available?
Thanks.
Win 10 64-Bit
32 Gb Ram
3.6 GHz Intel Xeon
Nvidia Quadro M2000
5 REPLIES 5
BenLoosli
(To:Modulerics)
How many cores do you have?
Is Hyper-Threading enabled?
4 Cores.
How do I check that is enabled?
BenLoosli
(To:Modulerics)
Task Manager Performance tab and select CPU
On the bottom right, it will say Cores: 4 and Logical Processors: 8, if hyper-threading is enabled.
Since Creo is single threaded, the highest CPU usage would be 12.5%.
Yep,
Cores 4, Logical Processors 8.
I guess it only uses the processor for generating Full Geometry Lattices?
Or is there some other way I could get this to generate?
What would a computer need to be highly capable with lattices?
I guess I should contact PTC and see what they say.
Thanks.
YES, contact PTC Support and ask them.
Martin Hanák
