Creo 4.0 unable to start due to (-97) The desired vendor daemon is down error
SandeepKadam07
Dear all,
I have recieved latest license file for creo 4.0. I am able to run creo 2.0 & creo 3.0 using that license file.
But only at the time of creo 4.0 launch getting this error.
5 REPLIES 5
it looks like FLEXnet is not running on your PC ...
MH
Martin Hanák
Dear Martin,
Please find below screenshot. I always ensure if flexnet services is started or stopped.
unfortunately checking the status of Flexlm Service 1 in Services dialog box is not the right way, how to check if license manager is running properly on your PC.
1.]
You have to check running processes ... can you see ptc_d.exe process running ?
What other processes can you see ... lm_admin.exe, lmgrd.exe ?
2.]
You have to check the contents of FLEXnet log file ... it can contain error messages...
Questions:
a.]
What FLEXnet version is installed on your PC ?
b.]
What "combination" do you use ?
lm_admin.exe + ptc_d.exe ???
-OR-
lmgrd.exe + ptc_d.exe ???
MH
Martin Hanák
Dear Martin,
Please see below attached log file for details
in C:\license.txt you can see the following error message:
File not found. C:\Program Files\PTC\FLEXnet Admin License Server\i486_nt\obj\ptc_d.exe
I guess that the above mentioned path to ptc_d.exe is set in license.dat file.
i486_nt is related to 32-bit version of FLEXnet.
In case that you have 64-bit installation, you have to use C:\Program Files\PTC\FLEXnet Admin License Server\x86e_win64\obj\ptc_d.exe path.
MH
Martin Hanák
