Creo 6 and Model tree width definition
gfraulini
I want to use Creo with browser in a separate window because I'm better with Windchill.
Since Creo 5 I have not problems, but now with C6 is has disappeared the command (in Options) to set the width.
There is a solution or a workaround?
In this manner you don't set it, you just move it.
Every time you open a file or start Creo you have to adjust the tree's width.
Up to Creo 5 you could set the width via Options.
Now I found the way: you haveto set manually (by drag, for each type of file (.asm, .prt, .drw) ) the tree's margin, then go into Options/Window Settings and make OK to force Creo to save the actual UI.
The next time one opens Creo you will find the desired nterface.
7 REPLIES 7
please provide more details ...
1.] What config.pro option do you use to show browser in a separate window
2.] What UI setting do you use ... attach picture
Martin Hanák
Here they are
Bye
2.] if I set WEB_BROWSER_IN_SEPARATE_WINDOW yes in config.pro and launch Creo 6.0.2.0 then standalone Creo browser window opens
Martin Hanák
The title: how to set the model tree's width
to set Model Tree width in Creo 6.0 simply move right border of Model Tree using mouse.
Martin Hanák
