While Creo is installing it sometimes reboots the computer mid way through the install. This is very undesirable behavior. Any ideas to get it to stop doing that?
What version/build of Creo 7 are you installing?
Is your computer compatible with the Creo minimum requirements, OS version, RAM, Graphics card and drivers?
7.0.4.0 and after rerunning the setup.exe it installs and works fine. No issues there, just the pesky reboot in the middle. I do my installs remotely and the reboot makes the process that much harder.
