Creo 8 is compatible with 11.16 or higher.
Reference aticle https://www.ptc.com/en/support/article/CS343197
If you're going to upgrade your servers, you'd probably be better off just going with the latest FlexLM. Our IT folk flagged my Creo 4.0 era license server as a security risk. I worried about compatibility with older versions of Creo and the latest license server, but was informed that things work fine.
Here's the discussion I had on here pertaining to FlexLM upgrades:
Definitely will be upgrading for the newest one.
For now I don't have such option.
So the question is: will Creo 8 will work with LM 11.14.1.2 ?
"FLEXlm/FLEXnet Server Version and Flexnet enabled applications Compatibility Matrix": https://www.ptc.com/en/support/article/CS154266
Thanks Vladimir,
I read this already 🙂
I might be wrong, but the header at the table says: FLEXlm/FLEXnet Server Version (Shipped)
It does not indicate clearly, that this is required for each Creo version.
