We are currently experiencing a service disruption impacting community and support login. Our teams are working to resolve the issue.
Creo 8, can't get CreoView Adaptors toolkit to load
davehaigh
I've loaded Creo 8.0.2.0 and CreoView Adaptors 8.0.0.0, I copied the install folder to a central location and have set my protk.dat paths to that location. I've double checked the paths in the protk.dat by using the dir command in a command window to list those files. I've done this many times before with Creo 4 and earlier, no issues.
With Creo 8 I'm getting this error: Creo Toolkit registry file: C:\Users\haigh1\pro\Creo_8_Home\protk.dat: cannot spawn application `proe2pv`; read error `No such file or directory`
I'm having similar errors with other toolkit applications we have. All have worked fine in Creo 4 and previously.
4 REPLIES 4
Article - "Creo View Adapter: Creo worker fails to start when launching in Worker Agent Administration in Windchill PDMLink": https://www.ptc.com/en/support/article/cs203231
davehaigh
(To:VladimirN)
The issue appears to be the protk.dat can't deal with %USERNAME% in the path. If I hard code the path it works.
Is there any way to use a variable in this file? Different syntax?   $USERNAME perhaps?
llie
(To:davehaigh)
We use these variables.
creotkdat $VIEW_SOURCE\tools\proe\$PROE_REL\toolkit\RCT\RCT_tk.dat
ABDL_Samir
6-Contributor
(To:davehaigh)
