hello there, I just downloaded Creo 9 and while working on my project suddenly the application shuts down . I opened Creo again but it is not responding at all, it has been three days now and it is still not opening or responding. Has anyone got a similar issue?
I am not yet on Creo9, however, have seen similar behavior on most versions at one point or another. I just saw what sounds to be a similar problem in Creo7 where as soon as I renamed the users .ui file he could use Creo again.
If that doesn't work some other possibilities to try:
@KA_10055605 , did anything I post work for you?
If deleting the cache works, we found another case where going into a non-Creo standalone browser and deleting items from the active workspace also has fixed an issue with Creo crashing as soon as logging in.
