Creo Elements Direkt Modeling Express kann nur offline betrieben werden
bung1
Hallo,
ich benutze Creo Elements Direkt Modeling Express 6.0. Seid gestern bekomme ich die Meldung, dass keine Internetverbindung besteht und ich nur offline arbeiten kann. Allerdings besteht eine Internetverbindung. Was kann ich tun?
Gruße
10 REPLIES 10
mcielok
(To:bung1)
Dear bung1,
your message was clear to me thanks to Google Translate Smiley Very Happy; this situation happens from time to time and I too am looking for a solution.
The problem is in charge to PTC: their license authentication service is off. I looked among other posts to find a Community manager to ask for PTC action.
I don't know whether she is on this side of the ocean or the other, so it could take a whole day before seeing answers. I'll tell you if I get one.
Marco
bung1
(To:mcielok)
Hello Marco,
thank you for your reply. My English is not so good.
Can it be that PTC no longer wants to support this system?
Bung
mcielok
(To:bung1)
Hy,
in my experience, PTC will is hard to understand.
But since many years this recurring problem is due to temporary issues with the authentication service.
I observed the problem occurred in the week end of the new european General Data Protection Regulation. Who knows if it has anything to do with it.
Marco
mcielok
(To:mcielok)
Bung,
no news yet, at present.
I have just sent a new message to the administrator.
If you'd like to have her bombed with requests, search for "Jaime Lee" and send her a message.
Let's stay in contact for any news.
Marco
Good Afternoon
I am reviewing this issue and seeking as to why it is still occurring for you.
I will provide an update as soon as possible.
Matt
mcielok
(To:MattDonovan)
So kind of you Matt, thank you very much.
Marco
FriedhelmK
(To:bung1)
Hallo bung1 (for English see under)
Falls du nach der mitgeschickten Fehlermeldung nicht weitergekommen bist,
Einfach ohne Eingaben auf Abschicken drùcken,dann Aktivierungsschlùssel anfordern drùcken,
Du wirst im Internet auf die Loginseite kommen, Einlogen
Dann bekommst du einen langen Aktivierungsschlüssel, Auswaehlen, (mit CTRL C) kopieren
im Fenster wo du den Schlùssel angefordert hast bei Manuelle Produktaktivierung (mit CTRL V) einfùgen,
Abschicken
Jetzt kannst du 72 Stunden arbeiten,
Dannach dann das Ganze  erneut,
Wir hatten auch den Fall dass einer auf der Skihùtte ohne Internetzugang arbeiten wollte 😉
In dem Fall kann man durch das Zurùcksetzen der Systemuhr Arbeitszeit "erschaffen"
Hoffe das hilft 😉
Gruss Friedhelm
Warning: counters english 😉
If you did not progress after receiving the error message,
Just click on Submit, then click asc for activation key,
You will come to the login page on the internet, log in
Then you will get a long activation key, select, copy (with CTRL C)
in the window where you requested the key, insert in manual product activation (with CTRL V),
Send
Now you can work 72 hours,
then the whole thing again,
We also had the case that somebudy wanted to work on the ski hut without Internet access 😉
In that case you can "create" working time by setting the system clock back,
Hope that helps 😉
Greeting Friedhelm
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
bung1
(To:FriedhelmK)
Hallo Friedhelm,
danke - hat diesmal funktioniert. Beim letzten Versuch ging der Schlüssel für die Aktivierung leider auch nicht.
Auf diese Art kann ich wenigstens das Programm nutzen,
Gruß
mcielok
(To:FriedhelmK)
This time the manual activation works.
Thank you very much.
In the meanwhile I received reply from Jaime Lee linking the thread https://community.ptc.com/t5/System-Administration/I-get-no-license-from-ptc-server-and-can-t-start-ptc-creo/m-p/552345#M19852 whit the same workaround.
Marco
bung1
(To:mcielok)
Danke Marco und Matt
