Has anyone gotten it to work? When I open it, nothing happens. Run as admin, nothing. Run in compatability, nothing. Ideas?
First I uninstalled the 64 bit version and restarted my system.
Then I installed the 32 bit version on my system.
You have to check the box for a non standard installation.
It opens up and runs fine. The only other thing I had to do was install Java for the Help component to function correctly.
Have fun
Message was edited by: Chris Behymer
I'm running Windows 8.1 Pro x 64 and nothing happens for me either. I think I am going to try the 32 bit version instead.
Have fun
Thanks Chris! Works great now. Funny that it happens that way.
