Creo Elements to Creo Parametric Bulk Conversion
savinash
6-Contributor
I am using Creo Elements Direct Modeling
Is there any Tool Available for Converting Creo Elements Direct Modeling and Drawing to Creo Parametric Assembly and Drawing.
Source Formats: .PKG, .MI, .BDL required destination formats: ASM, PRT and .DRW
2 REPLIES 2
VladimirN
(To:savinash)
Article - "Is it possible for to bulk conversion from *.mi and *.pkg format (Creo Elements/Direct Modeling) files into Creo Parametric files": https://www.ptc.com/en/support/article/CS386278
hadardor
(To:savinash)
Creo Parametric can import BDL file from Direct Modeling with possibility retrieve both 2D and 3D items. Refer to picture.
