Creo Hardware Compatiblity
Sudhanshu
8-Gravel
I have HP800G1,i7/4thGen/4790/Quard Core/ 16GB DDR3 RAM/ Quadro 2GB Graphic Card/ 1TB HDD and want to work on windows 10 or 8.1 pro. Kindly confirm which Creo Version will be work perfectly on that as I didn't find in Hardware notes of Creo 4 and creo 5.
6 REPLIES 6
I think you can install any Creo version, even if HP800G1 is not mentioned in Hardware notes.
Martin Hanák
Thanks, Everybody to clarify my doubts.
@Sudhanshu
It is not tested or certified by PTC as it is not listed in Hardware notes. As Martin mentioned install Creo on that machine possibly it will work..
Dale_Rosema
(To:Sudhanshu)
Dale_Rosema
(To:Dale_Rosema)
BenLoosli
(To:Dale_Rosema)
When PTC says minimum memory, they mean just that!
8GB would be my recommended minimum!
We have had a few files that struggled with 8GB. Had IT install another 8GB and that solved most of those issues.
