I have HP800G1,i7/4thGen/4790/Quard Core/ 16GB DDR3 RAM/ Quadro 2GB Graphic Card/ 1TB HDD and want to work on windows 10 or 8.1 pro. Kindly confirm which Creo Version will be work perfectly on that as I didn't find in Hardware notes of Creo 4 and creo 5.
I think you can install any Creo version, even if HP800G1 is not mentioned in Hardware notes.
Thanks, Everybody to clarify my doubts.
It is not tested or certified by PTC as it is not listed in Hardware notes. As Martin mentioned install Creo on that machine possibly it will work..
When PTC says minimum memory, they mean just that!
8GB would be my recommended minimum!
We have had a few files that struggled with 8GB. Had IT install another 8GB and that solved most of those issues.
