Creo Help Silent install XML missing
bmüller
just creating Silent Creo 2.0 M250 setup and tried to add Help Center.
But I can't find the creo_help_...p.xml files.
https://www.ptc.com/en/support/article?n=CS282324
Installation Creates the folder: Creo 2.0\Help\help
but no <Creo_Load_Point>\help\creo_help_<app_name>\
Setup with Creo 2.0\Help\bin\pim\xml\creohelp.p.xml only gives an error.
can anybody provide me the files for Paramteric and Simulate?
br Bernhard
make a copy of Help installation, put it into zip file and used this zip file for you silent installation.
Set PTC_HELP_CENTER_URL variable pointing to directory containing creo_help.exe file. This variable informs Creo 2.0 about Help location.
Martin Hanák
2 REPLIES 2
Martin Hanák
bmüller
(To:MartinHanak)
Creo 2.0\Help\bin\pim\xml\creohelp.p.xml seems to be the only XML file. Next morning it worked 🙂
We are just testing XML based setup, if it has some benefits over copying.
