Can I make a simple to implement suggestion (and it is simple) relating to application icons?
Currently when you install Creo the icons for all versions are identical (so the Creo 5 icon is the same as Creo 6 etc). If you have multiple versions installed this can - and does - lead to simple errors opening the wrong version and occasionally results in files being updated to the new version.
A very simple solution - which SolidWorks and other use - is to add the version to the Icon. So rather than just a simple box with a blue box, have a box with 6 in it, or 5 -you get the idea. Maybe even change the colours as well?
Or just change the icons between versions. Anything is better than the current confusion.
Suggestions for change in application can post in Ideas section for Creo..
https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
Thanks have done that now.
please do not expect that PTC will fulfill your request. Simply do it by your self and upload your icons to make other users happy 🙂
True, I could do it, but seeing as how we pay PTC every year for subscription services I really think this is one they should do. In my (long) experience of CAD vendors, if you don't tell them something is wrong from a UX point of view they assume all is well. But there is a balance to be had in suggesting major structural changes (like multi body part modelling) and things that will take their icon designer 2 mins. I'm suggesting this is in that latter category 🙂
This is a very important request, which already exists in almost all software
