Try this:
start "Creo 1.0 Parametric" "C:\<where you=" loaded=" it=">\Parametric\bin\parametric.exe"
-Dave
Hi Doug,
I'm having the same issue. Did you ever figure it out or get any help?
Also, I've always loaded the config.sup file to the loadpoint text directory. They've changed that and the two text directories I did find don't recognize the config.sup file because the options don't show up in Creo.
Frustrated,
Joe
I believe Dave Engel provided the solution. I had to deal with this back when I first installed F000 of Creo 1.0
Works fine when you use the example Dave provided.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
In Reply to Doug Schaefer:
We just installed Creo1 and ran into this same issue. Just so that I understand, you guys are NOT loading the PSF file that is in the bin directory then? What exactly does that file do, and why did they put it in there, if we don't really need it???
Darrin Hiebert
Here's the command I used, based on info from the exploder, probably
from Dave Engel.
start " "C:\Program Files\PTC\Creo 1.0\parametric\bin\parametric.exe "
Works great, even for other versions of Pro/E.
