Creo Parametric 1.0 Config and Setup options now avaliable
ocorten-2
Hi All,
I'm sure most of you are curious about all the Config and Setup options in Creo Parametric 1.0.
I just added them to my ProESite Check them out.
Note: Make sure to read the disclaimer.
Use undocumented/hidden options at your own risk. You might even corrupt models if you use them.
Kind regards,
Olaf Corten
www.ProESite.com/ www.CreoSite.com
Olaf,
Your the best. Thanks for making this available.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
