We have a couple of older, backup laptops that run Windows XP 32. They had older versions of Creo 2.0 (M0404 or M060, I believe) that ran OK. I upgraded them to M080 and now Creo 2.0 Parametric won't start.
I have not tried a complete uninstall and reinstall. That's next but I thought I'd ping the group here first to see if anyone had any other ideas.
The documentation indicates that Creo 2.0 is supported on XP, both 32 & 64 bit. The older build did run fine.
Any suggestions?
Well, I should have waited. Uninstall and native (non-XML based) reinstall fixed it. Not sure what the issue was, but it is fixed now.
Thanks anyway.
Thanks anyway.
