You might see 10.0.5.0 support SolidWorks 2024 when it is released in June.
Creo 11.0.0.0 was released after 10.0.4.0 and it only supports SolidWorks 2023, too.
It does take time for PYC to verify that any changes in SW are compatible with Creo and don't cause issues.
The delay between version releases is something that all companies go through when they use multiple vendors for their solutions.
Hello Ben
Thank you for your feedback.
Hope this is the case with 10.0.5.0 🤞
I know the pain with 3 systems running in parallel....
Marc
If you can login, here is a link to the Creo 11 product matrix.
Nothing is mention about Unite.
https://release-advisor.ptc.com/releaseMatrix?releaseId=1918
There is a plan to support SW2024 in Creo Parametric10.0.5.0.
As validation is still in progress, support for Creo Parametric10.0.5.0 or Creo Parametric10.0.6.0 can be confirmed by end of May.
