Creo Performance in VDI
NareshJ
8-Gravel
One of the team is using Creo in VDI (Virtual Desktop) environment & facing performance issues when tried to open assemblies and drawing files. Kindly share some best practices to enhance the performances.
Naresh
8 REPLIES 8
VladimirN
(To:NareshJ)
Some discussion on this - "Virtual Desktops for Creo - Questions?": https://community.ptc.com/t5/System-Administration/Virtual-Desktops-for-Creo-Questions/td-p/855
Naresh
please provide more details concerning "performance issues".
Martin Hanák
Hi
Below are the details of VDI. Kindly suggest.
Attribute
Value
CPU Cores
16
Memory
64GB
vGPU
nvidia_a40-8q
hard Disk
350GB
OS
Windows 11
Naresh
I expected a question or problem description.
Martin Hanák
Hi Martin,
User is experiencing slow in opening up creo files, above is the configuration of the VDI.
Hope this info is sufficient.
Naresh
@NareshJ wrote:
Hi Martin,
Naresh
I'm afraid I can't help you "remotely" (nor can anyone else). The problem must be solved by someone who knows the computing environment and can perform tests.
Martin Hanák
StephenW
(To:NareshJ)
I don't have any input on virtual displays specifically but things you can do are get a model opening speed comparison when opening from a local machine vs the VDI. Also check connection speeds.
Also, opening the model directly on the virtual machine, just to see if the problem is within the virtual machine or the connection.
rreifsnyder
(To:NareshJ)
Please note the actual CPU, the number of cores is irrelevant, Creo is mostly single threaded so what you really want to do is to check the cpu single thread performance here https://www.cpubenchmark.net/ . If this is a server based VDI, as most are, then they usually use Xeon processors which have large variability in their single thread performance, most are very poor.
