Hi All,
Is there a config option to automatically select the "Continue" option when a part has been opened and is asking to be checked out? I have a team member who will never be making changes that require saving and thus having such an option enabled will prevent him from checking things out erroneously.
Many thanks,
Andy
This is the config.pro option to use:
dm_checkout_on_the_fly continue
Cracking. Thank you.
