hi i'm new to creo and i just wanted to know will the 3.0 work on windows 10. And what are the limitations of the student version.
Windows 10 operating system is supported starting from Creo 3.0 M060 (I hope). Student license enables you to create parts, assemblies, drawings. Data created using Student session cannot be opened in Commercial session.
MH
MH
you information is correct Martin.
Thanks for the helping. So can I render and use all features of rende? And can I save save the work on to my system?
YES, you can save the work on to your system. Also basic rendering functionality is available.
MH
I knew this question got solved, I am just curious thou ,
I got a good article for you to install PTC creo 3.0
Here: https://extrudesign.com/installation-of-ptc-creo-3-0/
All the best
