Creo nor setup.exe does start
Spedex
today I tried starting Creo (9.0.0.0 Student Edition), but it did not work.
Also tried running as admin of course.
So i decided to uninstall it and reinstall it. Now the setup.exe does not want to start.
When i copy the files in a virtual machine (Windows Sandbox), the setup.exe does actually run.
I also tried deactivating Windows Defender, but also this did not work.
Absolute path is: C:\Users\chris\Documents\MED-100WIN-CD-460_9-0-0-0_Win64
Restarted the PC multiple times.
All drivers are updated to the newest version.
Does somebody know what could have happend?
Greetings
Spedex
Spedex
(To:Spedex)
Could not really find a fix.
I tried downgrading to an older Windows 11 version, but the downgrading did not work.
Then I re-set my whole PC. I assume it would work now but I did no check cause I do not need Creo at the moment anymore and I don't want to install it just for checking this.
Greetings,
Spedex
6 REPLIES 6
VladimirN
(To:Spedex)
Please specify what version of OS are you using?
Spedex
(To:VladimirN)
I am using Win 11 Pro (64 Bit).
also tried it with creo 7, did also not work.
Did not update the operating system nor any drivers.
Only update I did in the meanwhile between the last time it worked and now was the following: https://support.microsoft.com/en-us/topic/september-13-2022-kb5017328-os-build-22000-978-40843fca-a0be-4a60-b68b-6cb23a73a5aa
bro i also install 9.0.0.0 student version ,it sucessfully installed but when i open it shows error 0x06000012 and shutdown automatically.it shows because it could not run the quality agent,which is required in this edition. please help me bro its very urgent.
StephenW
(To:Spedex)
Spedex
(To:StephenW)
Can neither deny nor accept this idea. See my "solution".
Spedex
(To:Spedex)
Greetings,
Spedex
