When i click on creo parametric help button, a new window is displayed with esupport page? How do i get access to creo parametric help center
But when I click on Creo Parametric Help button, why it is directing to esupport page when help center is already installed?
You can also use "PTC Help Centers" via online:
to avoid "jump" to web page:
1.] install Help Center locally on your PC
2.] configure Creo startup psf file properly
Creo startup psf file located in Creo bin subdirectory must contain following variable definitions:
MH
Hi Martin,
Originally I was getting error when I click on the PTC creo parametric help icon within CREO 3 parametric session. I went ahead and edited the psf file by adding the variable that you have mentioned. However when I click on the icon again it opens the default home page set up within my Internet Explorer. Could you advise what I need to do to ensure the help page opens correctly?
thanks,
Ananth
Have you tried to set the Environment Variable directly in windows?
Which URL is displayed in the browser address bar?
btw. works for Creo 4.0 & 5.0 the same. Just replace the last digit:
br Bernhard
The problem was reported only for CREO 3; For CREO 4, we are good with the help center.
