We switched from proe wf4 m210 to creo/pro2 m030 3 weeks ago and experiencing a lot of crashes on the very basic functions:
file save -> intermitent crash or lock up
file save as-> intermitent crash or lock up
switching between creo windows -> crash
PTC has already multiple SPRs opened on these issues - to be resolved in m050 or m060
D
Just an FYI:
We've been using M020 since December with no real stability problems. Not sure if you want to try that build or not.
In Reply to Dmitry Ushamirsky:
Oh goody, Creo2 M060 should be out by the end of June, only 15 months after the F000. Sounds about right.
In Reply to Peter Wessberg:
Dmitri et al,
Our PTC TSAM told us to avoid Creo 2 releases below M050 due to quality issues. If I recall correctly M060 should be the release to go for.
/Peter
we also went to M030 2 weeks ago and experience crashes and freezing, we are now testing M040, sometinmes as simple as selecting Table in a drawing
We are running Creo 2.0 M020 with no stability issues. I also agree with Ben and always install my builds into different folders. If a new build has issues, I simply change the path on our start up script and everyone is back on the previous build.
"Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
So, it is 4/26/13 and I am downloading m050 now (it was supposed to be out 4/17/13, just showed up today in the downloads)
Let’s see…
