I installed Creo 9 student-Version in VM-Ware. The installation worked well and I am able to start Creo.
But when I create a new part and a new sketch, the references don't seem to match the planes. (see pictures).
Also when I zoom out the references dont line up with the referenced plane anymore and move up/down...
What is wrong here ?
I seems to work now.
For other people having the same problem: Deactivate 3d acceleration in VMware-Settings (display).
Just wondering if it being an assembly file instead of a part file makes a difference?
We don't normally create sketches in an assembly, except for AFX routings.
It doesn't make a difference. Assembly and Part. And every sketch (in every feature)
