Creo2.0 Student Install Issues
ptc-6390720
While i was attempting to install Creo2.0 on my computer it froze and i had to restart it when the Creo Common Files were only about 10% fully installed. I can now no longer continue to install the remainder of the common files which is also cause me to not be able to run any of the installed parametric, direct etc.
I have tried searching for ways to completely remove all the files associated with Creo so that I can try to reinstall. I have also tried two system restores on my computer to no avail.
Hoping that someone can help me with a solution as I have assignments that need to be finished asap.
Kyle,
simply delete Creo installation directory.
Martin Hanak
Martin Hanák
3 REPLIES 3
Kyle,
Martin Hanak
Martin Hanák
Thanks Martin, but how can i do that exactly? I'm not very computer savvy.
After a bit of playing around and some patience I've finally managed to get Parametric up and running. Thank you
