Creo2 M020 Freezing
ptc-3006345
Creo2 M020 Freezing
Our use's Creo2 M020 cache are getting corrupted for no reason has anyone had this as a reoccurring issue.
Take care,
JEREMY HANDLER
Mechanical Engineer
1+760-591-7318
[Description: Grren] Consider the environment. Consider the impacts.
Are you running this with Windchill? Is your cache set to the same location as Wildfire?
Andy Hermanson
Engineering Design Applications
tel 605.275.1040 x51114 mobile 605.310.8168
website www.daktronics.com
Hello all,
My current machine T3500 precision Dell has started random unexplained shut down and restarts. Dell has offered to replace my workstation with one as specified below. Can anyone tell me if this will work as well or better than my current machine? We are running WF3 M100.
Thanks!
QUADRO 2000
GPU Specs:
NVIDIA Quadro GPU
Quadro 2000
CUDA Cores
192
Form Factor
4.376" H x 7" L Single Slot
GPU Memory Specs:
Total Frame Buffer
1 GB GDDR5
Memory Interface
128-bit
Memory Bandwidth (GB/sec)
41.6 GB/s
Display Support:
Dual Link DVI-I
1
DisplayPort
2
# of Digital Outputs
3 ( 2 out of 3 active at a time )
# of Analog Outputs
1
Maximum Display Resolution Digital @ 60Hz
2560x1600
3D Vision/3D Vision Pro
[yes]
Feature Support:
Shader Model
5.0
OpenGL
4.3
Microsoft DirectX
11
SLI Multi-OS Technology
[yes]
NVIDIA CUDA Architecture
[yes]
Mosaic Technology¹
[yes]
NVIEW Display Management Software
[yes]
FSAA (maximum)
64x
Audio Support (via DisplayPort)
[yes]
Thermal and Power Specs:
EnergyStar Enabling
Yes
Maximum Power Consumption
62 W
Relative Performance Score
23.85
¹ Mosaic Technology will be available with upcoming driver release in Winter 2010.
T3600 Precision
Processors
Intel® Xeon® processor E5-1600 or E5-2600 family with up to eight-cores and Intel Advanced Vector Extensions, Intel Trusted Execution Technology, Intel AES New instructions, Optimized Intel Turbo Boost and optional Intel vPro(tm) technology
Operating Systems
* Genuine Windows® 7 Ultimate 32-Bit; Genuine Windows® 7 Ultimate 64-Bit
* Genuine Windows® 7 Professional 32-Bit; Genuine Windows® 7 Professional 64-Bit
* Red Hat® Enterprise Linux® WS v.6.1 EM64T (Also certified to run Red Hat Enterprise Linux Version 5.7 64-Bit)
Chipset
Intel® C600 series chipset
Memory2, 4
Quad channel; Up to 64GB 1600MHz or 1333MHz ECC and non-ECC DDR3 memory; 4 DIMM slots
Graphics4
Support for two PCI Express® x16 Gen 2 or Gen 3 graphics cards up to 300W (total for graphics):
High End 3D Mid-range 3D Entry 3D Professional 2D (not ISV certified) NVIDIA® Quadro® 6000 AMD FirePro(tm) V7900 AMD FirePro V4900 AMD FirePro 2270 NVIDIA Quadro 50005 AMD FirePro V5900 NVIDIA Quadro 600 NVIDIA Quadro NVS(tm) 300 NVIDIA Quadro 4000 NVIDIA Quadro 2000
GPU
NVIDIA Tesla® C2075 GPGPU - Supports Nvidia Maximus(tm) technology
Storage Options6
Up to two 3.5" or four 2.5" internal SATA, SAS or SSD drives.
SATA 7200RPM SAS 10K RPM SAS 15K RPM SSD Up to 3.0TB Up to 900GB 146GB 256GB
Storage Controller Options
