Creo2 installed, have a few questions
rcrisp
Users,
I just got Creo2 installed and have most things setup, but I have a few questions.
In my config I have (datum_point_tag_display yes) and it doesn't load the tags when I start up. I tried turning them on manually and saving out the config and restarting, still doesn't work. Anyone else see this issue?
I get a std.out
Allowing Crash: set_master_handler()
I get a std.err
pm_is_portmapper_port_busy: bind failed, error = 10013
Anyone know how to resolve these?
I'm not using a config.win file, it doesn't seem to be applicable with all the changes, so I just didn't use it.
Thank you
Ryan Crisp | Senior Mechanical Engineer
Priority Designs
501 Morrison Rd.
Columbus, OH 43230
(614) 337-9979
www.prioritydesigns.com
5 REPLIES 5
dgschaefer
(To:rcrisp)
Config.win is obsolete, Creo uses *.ui files that are loaded only from your user profile in Windows. I still haven't figured out what to do with that company wide.
Another issue is each software mode (part, assembly, drawing, etc) has different ribbons. So, changing the model tab in assembly mode will not make a change in part mode. Someone found 26 different 'modes' in Creo. Makes UI tweaking frustrating.
I get the same errors in my install every time. They don't seem to cause any issues, but we've just recently started more heavy use of Creo so I'd too be curious of a solution.
LinkedIn
AndyHermanson
(To:rcrisp)
As far as the .ui file goes, Look at
davehaigh
(To:rcrisp)
The message in the std.out file can be suppressed, but PTC doesn't recommend it. It indicates that Creo will create a traceback.log file when it crashes. You can turn it off with the config option auto_traceback never. See CS59617
I don't get the pm_is_portmapper errors. You should contact PTC about that.
David Haigh
Here is some information on the portmapper error:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS49331
<">https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS49331>
Document - CS49331
Document Actions
* Refresh Data
* Subscribe to this Document
<https://www.ptc.com/appserver/cs/view/subscribe.jsp?type=solution&refre
sh=yes&callnum=CS49331>
Document Information
Type
Article
Date Created
16-Feb-2012 12:45:42 EST
Date Last Updated
20-Mar-2013 17:48:14 EDT
Document Details
Title
Std.err file reports "pm_is_portmapper_port_busy: bind failed, error =
10013" in Pro/Engineer Wildfire 5.0
Description
* Std.err file reports following pm_is_portmapper_port_busy: bind
Applies To
* Pro/ENGINEER Wildfire 5.0 all datecodes
* Creo Elements/Pro 5.0 all datecodes
* Creo Parametric 1.0 - 2.0 all datecodes
Cause
Resolution
* Possible reasons for std.err file reporting error:
* Message usually brought up by service launched when
ptcportmap.bat (found in proe_loadpoint/bin) was executed on machine.
* ptcportmap.bat is a service used to link PTC
applications (either Pro/INTRALINK or any Pro/Toolkit tools)
* Old service, no longer in use
* TPI 104169
<">https://www.ptc.com/appserver/cs/view/solution.jsp?n=104169>
* TPI 118371
<">https://www.ptc.com/appserver/cs/view/solution.jsp?n=118371>
* Software EMC Legato NetWorker PortMapper installed
* Disable this software
* Related to ModelCHECK - TPI 114115
<">https://www.ptc.com/appserver/cs/view/solution.jsp?n=/114115.html>
* Environment variable PRO_COMM_MSG_EXE not set correctly
* Multiple versions of Simlab software installed
* System issue
* Example, out-of-date or incompatible OS library causing
low level communications to be dropped by operating system
David Krumwiede
Pure Fishing
davehaigh
(To:rcrisp)
So first off, that message about 26 different modes isn't correct. You don't need to customize the ribbon in that many modes. Once for each of the major modes will do it. Part, Assy, Drawing, Sheet metal, & Simulate. It doesn't matter if you bring up a Part from an assembly or from the open file menu, the ribbon for part mode it the same. (All I'm doing is defining a new tab and putting our custom mapkeys in that tab.)
Secondly, what I decided to do was not place a .ui file in the loadpoint. It makes it difficult if I want to make changes to it.
My startup script copies the .ui file down to the users cache location, and the config.pro also sets load_ui_customization_run_dir to yes
This allows the user to have their own customizations in the run dir, while I put the standard in their cache location.
The advantage of this is I can create a special startup script that only uses the .ui in the run dir, so that I can modify our "standard" .ui.
I added these line to my startup script:
1. del "%USERPROFILE%\pro\Creo_2_home\cache\no_pdm_cache\PTC\ProENGINEER\.Settings\creo_parametric_customization.ui"
2. echo f|xcopy "P:\Creo 2.0\dted_configs\creo_parametric_customization.ui" "%USERPROFILE%\pro\Creo_2_home\creo_parametric_customization.ui" /y /r
3. set PTC_WF_ROOT=%USERPROFILE%\pro\creo_2_home\cache\no_pdm_cache\PTC\ProENGINEER
Line one deletes any .ui that would be in the cache.
Line two copies the "standard" .ui file to the run dir
Line three sets the cache location
If you go to File, Help, System Information, you will see that there is only one .ui file loaded.
