Customize Screen Menu Option - Missing...
  • July 12, 2012
  • 1677 views
If I use my Config.win file that I have been using for some time now, the option 'Customize Screen' is missing from the 'Tools' menu.
If I rename my Config.win to oldconfig.win, so that Pro/E does not read it, the option reappears in the menu.
Naturally, I would like to use the Config.win that I have set up to my liking over the years, but I would still like to have the 'Customize Screen' option.
What have I done wrong this time?
How do I set my Config.win file to enable/disable certain menu picks?
I know I could just set my screen up the way I like it and save a new Config.win, but:
1. It will take me ages to get the whole thing back the way I like it,
and
2. I would like to know how I did this, so that I can avoid doing it again.
I am using Wildfire 2, M220
Cheers,
John
Hi John,
If you need to change your custom screen for ProE – you can select RMB (Right Mouse Button) and select Commands...
– it is same option like Tools >> Customize Screen in ProE
Vladimir
