Cut Out Operation - help needed
ptc-267878
i'm trying to cut one part out from another using Edit -> Component Operations. Then I get the following message error message:
Incompatible part size/accuracy. Change PRT_NAME accuracy to 0.000559 or use absolute accuracy to match part accuracies.
Edit setup the accuracies in the fly out box
