DHandles and memory
jcole
3-Visitor
DHandles and memory
I am using Creo Parametric Release N/A and DatecodeN/A
I would appreciate if you could please clarify the following for me about DHandles (pro_model_item in particular). Does the pointer to a DHandle  remain in memory, while the model it refers to remains in memory? For example when I use the ProSolidBodiesCollect function i.e,
ProSolidBody* bodies{ nullptr };
ProSolidBodiesCollect(proMdl) &bodies)
t* o_body_num; ProArraySizeGet(bodies, o_body_num);
 will the memory addresses for the bodies I get as output remain valid during a session? What I see is that I can actually copy the addresses and use them elsewhere in my code. Is this accidental? When I call the same function again I get different addresses for the bodies though, so if the addresses remain valid do I keep opening new DHandles by calling the function multiple times? Should I be closing them and if so, which function should I use to do so? Thanks a lot
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
