Decal Image Exporting Failure
ptc-5938561
I am trying to save an image of an assembly with a decal made from an imported .JPEG. Everything looks fine in the assembly, but when I do FILE>SAVE AS and save to JPEG or TIFF, jagged zebra-stripe artifacts appear on the face of the decal. I need a higher resolution image than a simple screenshot can provide, but do not have access to a proper rendering engine. Saving different resolutions and sheet sizes changes the stripe pattern.
Has anyone else encountered and resolved this issue? Thanks much
1 REPLY 1
The problem only seems to occur when the perspective view is enabled. Thanks
