Is there a config option that will set the defulat of the conflicts window to "OK" instead of "Cancel" upon a save?
The majority of the time, even with a blank model, the conflict "Mass properties are not calculated" appears for every model. Resolution requires two regenerations (one regeneration + save leads to "Model is not regenerated.").
mass_property_calculate is set to automatic. It looks like this has to be here in order for our drawings to update mass automatically.
I tried dm_checkout_on_the_fly continue. No change?
I also tried messing with dm_auto_conflict_resolution -- looks like this just skips the box altogether, which is not what I'm trying to do.
Any advice?
Thanks.
I'm not sure if this could solve your problem, but isn't it possible to create a mapkey/macro that regenerates your model (twice) and then save it?
This can replace your standard save-action.
