Detail view notation format
What we’ve always done is simply move the callout off the format – hang it out in space. Bad practice, I know – but that was the decision. And it works…
We had a manager one time demand no scales displayed on the drawings so we changed the scale note size to .001. You still get the SECTION A-A part but the scale note is just a little dot. Horrible work-around but it met the demand.
That manager has since left. Thankfully.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
I don’t know of any way to change/eliminate the view/scale note automatically, but you can certainly delete it. Just pick on the note and hit ‘Delete’.
RE: Detail view notation format
I submitted a Product Enhancement Request to allow the view_note option to match the detail_circle_note_text. So now we need votes to move it up the ladder for consideration. I know this seems trivial but I'm tired of having to change the text every time I create a detailed view. It creates a needless opportunity for a checker comment if I forget to change it.
Don
Don't forget to vote on your own enhancement in the forum!!
Steve Williams
Perhaps you should look at it this way. It's the checkers job to find problems. If they don't find something wrong, they will nit-pick just so they can mark something up.
This give them a bone they can go after, and they will be satisfied with that.
I see this in all kinds of government oversight jobs. It's their job to find problems, sometimes it's better to have a typo or some other simple obvious problem, so they don't start nit-picking other things that may add up to lots of work.
David Haigh
Sounds like we need a new config.pro setting:
obvious_error (yes/no)
Adds large text spelling error text to face of the drawing.
That'll do it!
-Ter
I am not sure exactly what you are asking for. I can tell you that the view
name text CAN be edited to add information under it.
Michael P. Locascio
I tried that post and it said something like "the post is not valid."
You need to be logged into the community and have active maintenance to see it.
LinkedIn
