Different Item number on different profiles in AFX
FM_10496372
I am using Creo Parametric Release 9.0 and Datecode9.0.2.0
I am using AFX and i know there is an auto number and auto generating name for parts and assembly. Is there a way to have the Item number generator different for each profile type? I'd like to have in my assembly a naming scheme for parts like this:
PROJECTNAME_I_BEAM_01;
PROJECTNAME_I_BEAM_02;
PROJECTNAME_I_BEAM_03;
PROJECTNAME_U_BEAM_01;
PROJECTNAME_PIPE_01.
Instead of actual naming scheme:
PROJECTNAME_U_BEAM_04;
PROJECTNAME_PIPE_05.
Hi @FM_10496372,
that is not possible at the moment with AFX. Is there a particular reason why you want the counter scheme like this?
Samuel Brantner
B&W Software GmbH
Hi again,
okay I figured out a little hacky way to stop afx from increasing the number. You can add a relation in your assembly that sets the profile_number parameter to a fixed value: PROFILE_NUMBER = 0
If you set that then AFX will always verify if the name is free from counter 1 and iterates thru all possible names until a free name is found. This could lead to some performance issues in large assemblies, but theoretically it should not cause any harm.
Hope this helps.
Greetings Sam
Samuel Brantner
B&W Software GmbH
FM_10496372
(To:SamuelBrantner)
Hi Samuel,
the reason is that a company i work for uses this particular naming scheme for their parts with an incemental number for each type of parts:
-HEA/HEB beam are named H01, H02, H03, and so on.
-IPE beam are nambed IP01, IP02, and so on.
-PLATES and sheet metal parts Z01, Z02, Z03 and so on.
etc.
