Dimensions - centerline/witness or extension line question
Newbie
An engineer here is complaining about how Pro dimensions to a centerline
of a hole. Here is the problem. I have a block with a hole in it. First, I
show the axis for the hole in the drawing view. Next, I show the
dimensions for the location of the hole. Instead of stopping the witness
or extension line at the end of the centerline, Pro extends the witness or
extension line to the center of the hole. It also prints and plots that
way. I told him when that happens to me I just pull the witness or
extension back to the end of the centerline. Is there a config or dtl
setting that controls this? Any other suggestions or work a rounds? TIA
for your help.
Wayne
