Displaying tolerances on dimensions in drawing
ptc-2716604
How do I display tolerances on dimensions in a drawing? I have the solid model dimensions toleranced the way I want them to, but i cannot get the tolerances to display on the drawing when I add dimensions. I have tried to use some of the config options: display_dwg_tol_tags to YES tol_display to YES tol_mode to plusinussym Thanks in advance.
Philip There is an option in the drawing options for showing tolerances under the same name as the config.pro one. Go to file/properties/Drawing options. It should be down the list a bit. This allows the tolerances to show in the drawing without having them show in the model screen. Next you can choice the type of tolerance in the dimension properties once the option is set. This all applies to drawings. Regards Eric
