Does Creo Elements Direct Modeling Express 6.0 support assembly constraints?
jmenoche
I have just installed Creo Elements Direct Modeling Express 6.0 and have gone through the tutorials to understand how to model in this environment.
The difficulty I am having is, I would like to assemble two parts, having the constraint remain constant, e.g. a pinned hinge that can rotate about the pins axis.
Watching the movement of the lid on the printer in the QuickStart tutorial called 'Repurpose a model to create a new product', it seems this is possible. However, I've been looking and can't locate proper contraints in the program. Additionally, when I watch the lid motion from the side, it appears the motion is not pure rotation, but an interpolated combination of translation and rotation from one position to another. It is basically faking a constraint using the configuration animation capabilities.
So, the question is, are there proper constraints somewhere in this free 'Express; version? If not, are they available in the paid version? Also, if not, shouldn't there be a clear mention of this in the documentation, help, etc?
I hope I'm just missing something.
Thank you - JM
lfortner
(To:jmenoche)
Hello John,
Dynamic Relations, a feature of the Advanced Assembly license is just available with the paid version, not with Modeling Express. I'm afraid you cannot within Modeling Express, set relations between parts and assemblies to design motions.
I run the "paid" version; I don't know what capabilities are available in the "Express" version. In the "paid" version, it is possible to add constraints to parts; to do that, you must activate the "Adv Assembly" module and use the commands in the "Relations" tab.
I don't know how that model in the QuickStart tutorial was built, but I doubt that any constraints were used. You are likely correct that the motion is not a pure rotation. When activating a configuration (which is what is done in the video), Creo Elements/Direct Modeling will move/rotate parts using an interpolated path-the shortest path to get the parts from their current position to the new position.
I have designed lots of parts that need to move like in that video and have almost never needed to add constraints. Configurations (like in the video) are a great way to get parts into new positions easily-you just can't trust the animation. In the cases where I do care about having an exact animation, then I use the "Relations" or "Animations" capability, or, more often, just use the dynamic positioning commands.
lfortner
(To:jmenoche)
Hello John,
