Drawing Options config
Dale_Rosema
In the last several months, the standards for our drawings have shifted slightly. Is there a quick way to change 8-10 parameters in the drawing config files with out have to change each one individually?
Also, is the a master list somewhere that shows what all the options (drawing and model) are and what task they perform?
Dale
Dale_Rosema
(To:James62)
My VAR stopped in last week and helped with a couple of issued that I had.
For fixing the drawings individually (WF5/Creo):
1. The drawing.dtl file was modified to the speicifications that was wanted on each configuration.
2. While in the drawing is open, File/Drawing Options:
3. In the pop-up window, pick the Open Icon (The folder opening icon).
4. Select the .dtl file that you need. (In my case drawing.dtl).
5. Select Apply.
6. Select Close.
7. Regenerate the drawing and the new specifications are in place.
Thanks to all for your help. Dale
7 REPLIES 7
I believe that after you change the .dtl file you're using, you'll still have to individually load all the dwgs and reload the .dtl file. Be aware of the need to check the dwg if you're changing text style, height, or aspect ratio.
Currently I am changing the parameters in each individual drawing.
What is the name of the .dtl file? (i.e. drawing.dtl, config.dtl?)
IIRC, the .dtl config is tied to the drawings once it is created. When you edit the list, it is the complete set (published). Each line has a description of what it is. You can type that config option in help and you probably get the exact same description but it may link you to more information. if you are on maintenance, you might be able to get to knowledge base, which could again add more info.
You can export one of the drawing's .dtl file and import it to other drawings... but be careful because it may overwrite settings that yoiu did not intend to overwrite.
I think a "config compare" funtion would be a nice tool to have.
hi Dale,
Have a look at the config.pro option called drawing_setup_file
The name of your *.dtl file can be whichever you choose.
~Jakub
ReinhardN
(To:James62)
@Jakub
this option will only work for new drawings if your drawing template does not have a .dtl attached
@Dale
if you can create a mapkey which loads a modified .dtl into a drawing you can use pro/Batch or Spekan Batch to apply this mapkey to a list of drawings.
Reinhard
James62
(To:ReinhardN)
Yeap,
Thanks for pointing that out.
Dale_Rosema
(To:James62)
5. Select Apply.
6. Select Close.
