Hello all,
I'm looking for a way to have my config.pro point to a directory for the drawing templates, rather than a specific template. We have about 21 templates which cover plastics, sheet metal, cnc, etc. across sheet sizes of A thru D.
The way it is set now is for a specific template, but I'd like it to point to the folder location so that the user can choose from those found there.
Is there a way to do this?
Cheers!
Config.pro et the following Creo variable:
start_model_dir {enter folder location where templates are stored.}
Same variable used for start files for CAD model.
Linette
^ Thanks for the suggestion, however this didn't work for me.
It works in Creo 2 M100
-check for spaces or illegal characters in folder specified.
Thanks for all your suggestions, however, I've not been able to get anything to work. To clarify my problem, I've got my drawing templates in Windchill. They are in the same directory as my start models and assemblies. No matter what I do, I can't seem to get the dialog box to show the contents of the desired directory. It always shows the contents of "C:\PTC\Creo 2\Common Files\M110\templates". I've not found any option in config.pro that sets this path.
Please provide what value you have in your config.pro for start_model_dir.
FWIW: I was correctly pointing to the WC directory in all cases.
I've given up and decided to simply copy the templates into the local installation directory where Creo is looking by default. PTC! Why is this so hard?
Huge thanks to all who chimed in with help. As it turned out, there was a very small typo in the various lines that pointed to the WC folder location. Some lines had "Windchill" while a few others had "windchill" as part of the path name. Capitolization makes a difference!
I've finally got it working, thanks again!
