Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Drawing Templates? No way to point to different folder?
When you create a new drawing, you get a list of templates that PTC includes in a local folder.
Is there a config.pro setting to point this somewhere else? Or are we stuck with putting stuff in the local folder?
If so, that is terrible.
On 09/05/12 17:05, Michael Gamber wrote: > When you create a new drawing, you get a list of templates that PTC includes in a local folder. > > Is there a config.pro <">http://config.pro> setting to point this somewhere else? Or are we stuck > with putting stuff in the local folder? pro_format_dir ie pro_format_dir ilcs://server3/Root Folder/library/formats pro_format_dir wtpub://WindChill/Libraries/CAD/ProEngineer/formats pro_format_dir /some/directory/path
> > If so, that is terrible. > > ----------
-- ------------------------------------------------------------------------ Randy Jones Systems Administrator Great Plains Mfg., Inc. 1525 E North St PO Box 5060 Salina, KS USA 67401 email: - Phone: 785-823-3276 Fax: 785-667-2695 ------------------------------------------------------------------------
On 09/05/12 17:08, Randy Jones wrote: > On 09/05/12 17:05, Michael Gamber wrote: >> When you create a new drawing, you get a list of templates that PTC includes in a local folder. >> >> Is there a config.pro <">http://config.pro> setting to point this somewhere else? Or are we stuck >> with putting stuff in the local folder? > pro_format_dir > ie > pro_format_dir ilcs://server3/Root Folder/library/formats > pro_format_dir wtpub://WindChill/Libraries/CAD/ProEngineer/formats > pro_format_dir /some/directory/path
Oops. I just realized you were asking for templates NOT formats. I think Antonius has it correct with start_model_dir > >> >> If so, that is terrible. >> >> ---------- > > > -- > ------------------------------------------------------------------------ > Randy Jones > Systems Administrator > Great Plains Mfg., Inc. > 1525 E North St > PO Box 5060 > Salina, KS USA 67401 > email:- > Phone: 785-823-3276 > Fax: 785-667-2695 > ------------------------------------------------------------------------ > > ----------
Start_model_dir points to a folder on disk that contains the start parts and drawing templates.
You can also use Template_drawing to point to a particular drawing template, using full path name, to be used as your default template. We have it pointing to our C-size part drawing template file.
