Drawing format for academic use
ProFeature
Hi
I am looking for a drawing format for academic use. mm, ISO, 3rd angle.
I'm looking for format that templates of standard part and assembly template will be linked to parameters (DESIGND_BY and DESCRIPTION)
@ProFeature wrote:
@MartinHanak I appreciate your willingness to help.
I'd like to use these two parameters in drawing format.
Thank you
please read https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/index.html#page/detail/to_retrieve_model_parameters_in_drawing_using_format.html#
-AND-
watch https://www.youtube.com/watch?v=lGT85r_f8Dw video (start at 10:00).
Martin Hanák
This Creo Parametric tutorial video shows how to create a new drawing format, including: * importing DXF * system and user parameters * adding symbols and notes For more information, visit https://www.creowindchill.com. If you learned something from this video, please give it a thumbs up. If you ...
12 REPLIES 12
I'm afraid you'll have to create them yourself.
Martin Hanák
Hi @MartinHanak
I found some formats and templates in the folder: C:\Program Files\PTC\Creo ##.#.#.#\Common Files\creo_standards\formats.
Unfortunately, no format from what I found there or in the subfolder is suitable and is not linked to a standard part or assembly.
This makes me wonder why the default standard parts and assemblies have parameters that aren't associated with anything.
Youtube ... creo create drawing format ... you will get a list of useful videos.
Martin Hanák
It saddens me that Creo does not address issues like these.
Academy users don't have a VAR or MCAD manager to help them with these issues. No surprise that students are "pushed" to use other CAD software...
if you have a specific problem, ask and I will answer you. Don't complain that you don't have what you want.
Martin Hanák
Thank you
Thank you
-AND-
Martin Hanák
Thank you @MartinHanak
BenLoosli
(To:ProFeature)
You are using the Student version of the software. It is for YOU to learn how to use it. Experiment, try different things, use YouTube videos to get ideas and examples.
The files that come with the system are examples and can be modified to do what you want.
Linking parameters in a part file to the drawing is easy. Put the parameter in a table with the parameter in the cell. Cell format should be &Description:MDL. This will pull the Description parameter vale from the model into your drawing table.
I'm a researcher looking for a solution to create a template that will allow me to send PDF drawings to production.
BenLoosli
(To:ProFeature)
The student and academic versions can NOT be used for production work. It is a violation of the license agreement..
The parts I make are for research activity.
