I have created an extrude in Pro-E 4.0 with sketch plane as Front plane and dimensions as 100 MM *125 MM *150 MM.
When I create drawing from this part, I have got scale factor as 0.010 on lower left corner.
This is what is confusing me as after saving drawing file into DXF format and measuring front view , actual value of 100 MM *125 MM is comes out as 25.91 MM * 32.39 MM which indicates scale factor as 3.85.
Thanks in advance for your help.
Ketan Lalcheta
