Driver hp designjet 755cm Windows 7
dgschaefer
We have the same problem here with our 1055cm. It's been suggested to
look for and try Vista drivers, sometimes they still work with Windows
7. Haven't tried it here yet.
Doug Schaefer
LinkedIn
I just found the drivers for my plotter.
I went to start -> Devices & Printers and clicked 'Add Printer' at the top of the window. I then followed the prompts to install a network printer. Mine is attached to the network directly, so it wasn't on the list, I had to enter an IP address. Then, it asked me to select it from the list. My HP 1055cm wasn't on the list, but once I clicked 'Windows Update', the list was refreshed and it was there. It installed just fine, however, it won't print via the command I used with XP (lpr -S <ip address="> -P <ip address=">). It does work through Windows Print Manager.
If I go to a DOS prompt and type 'lpr', I get ''lpr' is not recognized as an internal or external command, operable program or batch file.' I wonder if command line printing in Windows 7 is different ...
Doug Schaefer
LinkedIn
davehaigh
(To:dgschaefer)
Thanks for the info, my copy of Windows 7 was missing the Windows Update button in the Add Printer dialog. I finally found that someone had turned off the reg settings that allow that button to show.
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DriverSearching
REG_DWORD DontSearchWindowsUpdate to '1'
REG_DWORD DontPromptForWindowsUpdate to '1'
Reseting them to 0 cures the problem.
David Haigh
davehaigh
(To:dgschaefer)
I'm trying to get my server controlled publishing to work again, and I'm running into a problem with proeworker.bat not starting up properly under server control.
If I try to publish an object from windchill by clicking on the pyramid, the system hangs at Registering Server.
Sep 29, 2010 3:02:15 PM:Start PublishJob: Assembly - <name>.asm, AA.0
Sep 29, 2010 3:02:15 PM:"As Stored" Config Spec is available
Sep 29, 2010 3:02:15 PM:The EPMDocument As Stored Config Spec was selected as the default
Sep 29, 2010 3:02:15 PM:make temp dir <path> \pubtemp\publish666537055655258760.tmp
Sep 29, 2010 3:02:15 PM:Start: Assembly - <name>.asm, AA.0
Sep 29, 2010 3:02:15 PM:Authoring Application: Pro/ENGINEER
Sep 29, 2010 3:02:15 PM:empty temp dir: <path>\pubtemp\publish666537055655258760.tmp
Sep 29, 2010 3:02:15 PM:Transferring Files to: <path>\pubtemp\publish666537055655258760.tmp
Sep 29, 2010 3:02:15 PM:Number of Files (identified to be) Transferred: 7
Sep 29, 2010 3:02:15 PM:ProE Asm Conversion
Sep 29, 2010 3:02:15 PM:Added request to PROE queue
Sep 29, 2010 3:02:16 PM:No available connected worker
Sep 29, 2010 3:02:16 PM:Starting new worker <server name=">-PROE:1, attempt 1 of 3
Sep 29, 2010 3:02:31 PM:Job 14 submitted to worker: <server name=">-PROE:1
Sep 29, 2010 3:02:31 PM:LOGID: worker_3.log
Sep 29, 2010 3:02:31 PM: Registering Server
However if I remote into the worker machine and start proeworker.bat from the command line, then publishing works. To be clear, I'm starting that as myself, not the windchill user I have in the fileadapterauth.properties file. That user is just a windchill user. It has no login to the worker machine on its own. This used to work.
Any ideas? Suggestions?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
________________________________
davehaigh
(To:dgschaefer)
In the Update Group dialog there used to be a pick for recomputing the team membership.
In 9.1 I no longer see it. Where did this go?
[cid:image001.gif@01CB608C.C66C10D0]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Livermore, CA 94550
