Hello all!
To start, I do locally (without Windchill).
Created the mc_dup_model.bin file, as written in the requirements. But duplicates are still not searched. I understand that the values of the forms will be entered exactly in this file, but something goes wrong.
Also, Windchill will need to be configured, but there are also incomprehensible points here: it is necessary to create global attributes associated with certain model parameters.
How to create attributes in Windchill?
Best regards!
Hello!
I configured everything as it is written in the article, but the parameters MC_VOLUME, MC_AREA, MC_INERTIA_1, MC_INERTIA_2, MC_INERTIA_3 did not appear in the models.
I did everything from Creo and ModelCHECK, from Windchill I did nothing (I did not configure the parameters of global attributes).
Is this the problem or am I missing something else?
Best Regards!
Set SEARCH_DUP_MODELS in check file and MC_SI_PRINCIPAL_MI as Y in config_init.mc (restart Creo.)
