Hi all, I have an intern working with me and we purchased an educative with the EDU_COM_Convert floating module. Do you know if there's a way to configure Creo so this floating module is always loaded/active ?
I thought about using the reconfigure.exe to reconfigure the launching command, but this reconfigure.exe is not present in the educative version.
Nobody has an idea about this ? ![]()
