I had to format a computer, logos after configuring CREO this option that follows print is no longer enabled, before formatting the machine was normal, and same license and everything.
I guess you did not select Ansys Simulation item during installation. You have to remove current installation and do new clean installation.
MS_Santos,
2 quick things to check.
Dan N.
The license is CREO as shown in the printout, I've already transferred the license but it still won't enable.
