Error -9 requesting new student license for creo 8.0.4.0
PD_10684929
I have installed my CREO 8.0.4.0 student edition two months ago and now i get the Error message that the "license request failed for feature."
Error code -9.
Please find picture underneath.
JamesAvis
(To:MartinHanak)
Since you have Creo installed, navigate to the Parametric\bin folder in your Creo installation (you can probably find it by right clicking on any Creo shortcut, Open File Location), open a command prompt there (you can do this by clicking in the address bar, type CMD, hit enter), then enter the command:
ptchostid.bat
This will tell you what Creo sees as your host ID. If it does not match 98-AF-65-73-18-FB, you'll need to request a new license file with the correct host ID.
9 REPLIES 9
HOST-ID included in license file does not correspond with physical address of any network card installed in your computer.
Martin Hanák
Hi, thank you for your fast response. How can i get a license that corresponds with my physical address of my network? What do i have to do? I tried using the node Locked License Generation with the code BK800908EDSTUDENTEDUNI a bunch of times, but it just says Error after asking me for login details.
please do following:
  • upload MartinHanak_0-1733219541355.png file
  • open Command prompt window
  • run ipconfig /all > ip.txt command
  • upload ip.txt file
I will investigate both information sources and let you know what to do.
Martin Hanák
Please find both files below. I renamed the file sw_license_email_572119 to a text file, because it did not allow me to upload a .dat file.
did you really upload MartinHanak_0-1733229656014.png file? I can see sw_license_email_572119.txt file
Inside sw_license_email_572119.txt file I can see:
  • INCREMENT CREOPMA_Student6 ptc_d 40.0
    • 40.0 means Creo 9.0
  • HOSTID=PTC_HOSTID=98-AF-65-73-18-FB
    • this PTC_HOSTID is available in ip.txt
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX201 160MHz
Physical Address. . . . . . . . . : 98-AF-65-73-18-FB
I can't see any problem.
Note: Maybe OpenVPN adapters are causing your problem.
Martin Hanák
JamesAvis
(To:MartinHanak)
ptchostid.bat
ptchostid.bat
please next time send your reply to OP, It is @PD_10684929
Martin Hanák
PD_10684929
(To:JamesAvis)
Hi Mr Hanak
My Creo works again the way its supposed to. The thing is i use Creo at my university and need to activate the universities vpn to access their server through Creo. (I also use a program from my university, which opens Creo with their server - i never open Creo by itself). I believe there was probably a error due to the open-vpn and my local licsenz and the host ID. By using the prompt and command line you suggested i saw that the two Host ID line match. I probably did not have my vpn activated before opening creo.
Many Thanks
P
Hi @PD_10684929,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
