After installing Creo 2.0 M160 (M150 was flawless) the error prod_dcu.exe has stopped working, I seem to have cured it by doing a custom install and deselecting the option to use PTC diagnostics on each application. The installer still installs the PTC diagnostics.
Here is the XML from the event log
</System>
</EventData>
</Event>
Bill,
PTC Diagnostic Tools item is always installed during installation of Creo 2.0 M150+. If you use commercial Creo license, you can uninstall PTC Diagnostic Tools when Creo installation is finished. Simply go to Programs and Features and uninstall it.
Note: I don't know the purpose of prod_dcu.exe ...
Martin Hanak
Hi Martin,
It is still installed, I just told the installer not to use the diagnostic facility using the customize function, that seems to have stopped it popping up.
prod_dcu.exe reports the following when it is run in a cmd tool
usage: pdod_dcu product [ -flag ]... -element elemValue ...
here is the offending message that shows up when you start creo parametric, pressing Close the program dismisses the box, its just annoying more than anything else
